How much difference will a big bore make on my setup?
I have a 2013 DRZ
3x3
MRD/SSW
39FCR
Hot Cams stage 1 in/exh
What should I expect when I do the big bore? Is it going to be a WOW change? Or just another incremental change?
I would imagine a lot more TQ in the low end and mid range? How much of a higher RPM difference?
Basically overall, is this going to be a change that transforms the bike the way the exhaust/carb did?
I have a 2013 DRZ
3x3
MRD/SSW
39FCR
Yep.....Yep.....and Yep   You're gonna love it!
  • Like 2
Nice! I can't wait. It shipped today supposedly.
I think I am going to get a Hot Cams stage 2 intake cam eventually, but for now the stage 1's will have to do. I am sure with the extra displacement they will be worlds better than stock anyway.
Which BB kit did you get?
The difference will be similer to when you added a fcr carb. Lots more bottom and midrange power. Top end suffers a bit but once broken in it won't really be noticeable
If top end suffers some,  but you are getting more bottom end,  can you go down a couple of teeth on the rear sprocket to make up for it?
I went to a 14T front sproket, I can always put the 15 back on.  That would be nice for highway anyway.
with a 14 on the front you won't have to worry about front tire wear......probably never touch the ground now. ;)
  • Like 2
bigbores don't like to rev high like the stock bore does. Dropping a couple of teeth on the back does make up for it
My BBK seems to make the same or a bit more power up top, but the mid-range and bottom is so much better that I rarely rev it right out.
I think that most of that is related to the cams, exhaust and intake. With a set of aggressive cams, MRD and FCR41 it would likely gain quite a bit up top. However for how I ride it's just about right, I will probably spring for the WR trans one day.
-Grant
-Grant
A 39 will be better everywhere except over 8,000 rpm...
-Grant
Yeah , dead right :thumbsup:
It's win ~ win .. For you
The BB gives you more Torque , so .. You keep the Overall Revs down , this saves you flogging out the valves / Bottom end .
Is my OEM cyl/piston worth anything? Its only got 5000 miles on it, regular oil changes, full synthetic since 2000 miles.    Someone out there has to need a new top end and can't afford a BB kit I figure.
It wouldn't be worth a great deal......If you don't think you will use it you could place an add in the classifieds......
Edited by Craigo 485sm
I was thinking about saving it for a buddy who has a DRZ with like 40k miles on it (Its TheGardensnake's old bike) and not much money.  In case his pops I can sell it to him cheap (50 bucks maybe?) so he doesn't have to buy a $400+ BB kit.
Edited by Wrathchild
  • Like 3
