No Rim Locks on my 2003 s
I was about to install my new Shinko 244 but
when I removed the Tire theres no RIM LOCKs
theres this hole with a rubber plug(in the picture)
around 6to 7 inches from the tube valve
Is this Normal for a 2003 No rimlocks!!
[/url]">http://IMG_20140510_095532.jpg
[/url]">http://http://s82.photobucket.com/user/ito_ogami4/media/IMG_20140510_095255.jpg.html'>IMG_20140510_095255.jpg]
Rim locks make tire changes difficult. Just run at least 13 psi and you won't have a problem
Yes normal for the S models.  If you want rim locks, you need to add them.
Sir is that Hole with a Rubber plug for the Rim Locks..so i just remove the plug and put a rimlock!!!
Thanks!
Yes remove plug and install. But, beware this is going to change the balance severely. I added a rimlock after 5 tubes. Tried all different pressures, just kept ripping them.
