CRD DIY STUBBY - power loss?
Evening thumpers.
My bike, 2004 E, came with a full CRD absolute performance system. Lovely system although quite frankly it made a rubbish sound and was quite quiet. Made to be enduro legal I believe, so 91dB.
With the intentions of making it a little louder I decided to modify the end can. I may have got a bit carried away and I ended up turning it into a full on CRD ABSOLUTE STUBBY!!
I think it looks the part, and it weighs nothing!
But...
It's caused a loss in bottom end power.
What can I do to rectify this? The sound is nice and it is deeper.
Have I ruined the exhaust or can it be fixed?
I'm currently running the standard e system while I investigate.
Cheers.
ImageUploadedByThumper Talk1399752252.809328.jpgImageUploadedByThumper Talk1399752266.051774.jpgImageUploadedByThumper Talk1399752285.802199.jpgImageUploadedByThumper Talk1399752298.052547.jpg
Can you adjust the exit diameter, maybe big washer or end cap insert?
It still has a baffled section inside it. Do you think it's a back pressure problem then?
The bike pulling ok at the bottom , but the power doesn't feel as strong.....Is this correct..?
Any difference with the air box door removed..?
Is the airbox snorkel removed.?
Edited by Craigo 485sm
I have one of these in titanium, love it. The sound too!
Does the muffler still have packing? mine lost bottom end when the packing wool was gone
I shortened me MRD exahsut from 14 to 12 and did not notice any bottom end power decrease,  i think it looks good now that way you did it.
Craigo you're correct. I only did one test run as it was getting late.
But yes it ran and rode fine but there was a distinct lack of torque low down!
It doesn't have any wool now, it does have a baffle part inside but perhaps this isn't holding enough back pressure now.
And yes the snorkel is removed. Felt noticeably quicker with the e system back on.
mate, If it still runs crap after you re do the packing I reckon you have F#%ked it ....
And yes the stock E system is a very good design...
I'll repack it and see what changes I can make to restore the back pressure (I assume this is the reason for the initial bottom power loss!)
Maybe as stated earlier reducing the baffle size with a welded washer would help.
Now to drill those rivets..
Update, a good one!
So today I did some back to back testing with the stubby CRD and the E exhaust
My initial feelings were confirmed, the CRD had a lot less torque lower down than the E exhaust.
I went back to the drawing board and deconstructed the CRD again. Using the baffling and Glass Firewool (or whatever its called) I modified the size and packed it into the stubby.
This gave it a deeper more thumpy sound and really improved the performance. I am very pleased!
I will admit that performance wise it still doesnt pull like the standard E system does, but I put this down to jetting. Hopefully the stubby CRD can be jetted to out perform the E system.
After rigorous testing.. see pic...  nothing has fallen apart and things are going well.
The CRD now weighs no more than 4-5 kg, its half the weight of the E cannon.
Let me know what you guys think. I'm going to give it a good polish and tidy up the rivets soon.
Cheers.
th_trim911BA82B-74F2-4CFE-AA7F-51B2F1131
