How to Remove Double Throttle Cable from TTR125L?
Hi there.
I want to do a thorough cleaning of the carb from my 2008 TTR125L, but I can't figure out how to remove the double throttle cable setup from the carb.  Does anyone have any tips on how to do it?
Thanks.
First, remove both throttle cables from the throttle grip assembly up on the handlebar.
This will give you the slack in the throttle cables you need to make this easier.
Edited by YZEtc
Ah, that makes sense.  I will be taking the carb off tonight, so I am glad you replied.  I just wanted to see if there was some sort of trick involved.
Thanks. :thumbsup:
