What Jet Kit
I am doing the 3X3 mod and full system MRD or Yosh  pipe for my 2013.
I am thinking I will buy from the TT store unless someone has better option.
Can you assist with what jet kit, jet sizes and so on I should buy and any other parts I will need?
I also plan to buy the flex adjustment screw and use UNI filter.
I am not hip on the carb stuff so please speak in rookie language.
Thanks for the help.
Get the JD jet kit comes with everything you need, mainjets, needles, 25 pilot jet, and allen head float bowl screws.
You will needthe TT extended fuel screw, the flex jet fuel screw will not fit the mikuni bsr36 carb.
All of this can be sourced from ThumperTalk.
Jetting for 3000ft and below:
main jet 160 (open pipe) 155 (corked pipe)
needle Blue needle on clip 4
pilot jet 25 w/ stock fuel screw 22.5 (stock) w/ extended fuel screw
fuel screw 2.75 turns out
Owe you one Craig, fing thanks a bunch.
You guys are awesome.
Parts are on order from the TT store are per Wisconsin.
