LESS THAN 24 HOURS LEFT TO GET IN ON THIS! Read more... ×
Will and 02-07 Rear Fender Fit the 00-01 Bikes with no mods?
I know a front will cause that's what I run but not sure about the rear as the 00-01 has the intentions on the sides to fit flush with the side number plates. Guess you found a cheap combo on eBay? Is there not a white rear fender available for the 00-01? If yes then id just order a newer front and same year rear thats both white. I haven't looked in a while.
If the 01 has the second to fit flush with the plates then maybe. And fronts were different from 02-07, my 05 came with 03 fenders and the front wasn't as.... Sharp, is the best suited for it
