Kx125 clutch basket is slipping when kicking over? Help
I just bought a new wesico clutch and clutch basket for my kx. Everything went fine until I was riding it and it started to rev up for no reason. I pulled the clutch in the bike still reved so I shut it off and it took about 20 kicks to start. It usually only takes one. Took the case off and the clutch and when I kick the bike over the middle of the basket moves and the basket only moves sometimes. Can anyone help me out? Is this the problem with the bike?
Pictures would be good but from what you are saying it seems that some gear may be stripped. I could be wrong but I am pretty sure when you kick the bike over you are kicking the outer basket which spins the piston and rod. The inner basket which is the smaller one spins the transmission. It seems weird that the inner basket is spinning and the outer isn't.
