2000 ds80 kickstarter shaft replacment....split cases?
ive read a bunch of posts that state u just have to take off the clutch cover, remove washer and spring/gear and then turn the shaft a 1/4 turn(which is under tension from inside the cases) and then pull it out..........but this is not happening! lol......
am I looking at splitting the cases? im not 100% because how would u split the cases if u cant get the shaft out first?
any help would be appreciated.
Cases have to be split to get it apart.  the spring has a pin which goes throught the shaft to hold evertyhing in there.  My spare kick level is not very good, just looked at it.  someone even tried to weld it.  Sorry can't help u with parts.
I have the same issue.
I'm new to this.
Is there a video or diagram that shows you how to split the case?
