Quick question
Im about to take a couple things apart on my bike give it a little clean and maintenence also put some unabikers on, case savers, new chain and sprocket, mrd ssw, jets and 3x3, and hyde skid plate itll probably take me about a week to do everything. My question is should i give it an oil change before or after? (I already got the tt oil change kit) Also anyone have any advice installing any of these? I have everything i need i think except possibly an exhaust gasket. I have an 05 s model hoping everything installs easy, already have a little trouble with the skid plate, just lined it up to see if it would be easy and the stock header was kinda in the way but hopefully ill get it on
3x3 mod help:
http://www.thumpertalk.com/topic/1085110-what-jet-kit/ - at the bottom is a step by step instructions, witout a jetting guide, but it does tell you HOW to change the jets.
http://www.thumpertalk.com/topic/316850-the-master-3x3-post/?hl=%203x3
new chain and sprocket tidbit:
http://www.thumpertalk.com/topic/540670-counter-shaft-sprocket-loctite-fix/    - just had my front sprocket come off because i didn't do this to it. read for good info.
more info:
http://www.thumpertalk.com/topic/339955-every-thing-you-need-to-know-about-carbs/
http://www.thumpertalk.com/topic/939138-what-every-drz-needs-protection-reliability-fixes-common-maint/     -case savers info and what not.
anything i missed hopefully fals in here: http://www.thumpertalk.com/topic/540683-common-thread-reference/
and here: http://www.thumpertalk.com/forum/215-drz400-faq/
hope this helps, im about to do the 3 x 3 mod myself this coming weekend, along with the loctite fix, installing chain rollers, and adding a second computer fan to my radiator for cooling (old fan long gone, long story).
I would do an oil change after everything else. I don't think doing it before or after would really make a difference but that is just how I would do it.
I would change the oil first so you're not fighting to change your oil with a skid plate in the way (or dropping a bolt between the skid plate and bike - lol).
Unabiker radiator guards - there are two "support" bars that are on the back side of the radiator get the inside bolts tightened down first. Then remount your radiators and then finish with the outside Allen screws for the supports bars.
I'd do the oil change before you put that skid plate on. It's really hard to work with. I just bought and installed the Hyde. Really like it, but as I said in another thread, I hope I never have to take it off 'in the wild'. Fixxin' to do an oil and filter myself. Will prolly take the skid plate off to do it. I can only assume the oil will go all over the top of the skid plate if I leave it on.
