'05 450x - Weak Rear Brakes
Hi.  Brand new to this forum as I just bought an '05 CRF450X this week.  Lots of questions but I'd like to start with this one.  I have two problems with the rear brakes.
1) My foot can hardly engage the brake lever - stock.  i wear a size 16 shoe so i'm not worried that I don't have a big enough attack point!  Any good options to address this?
2) If I just use the rear brakes I can hardly slow the bike let alone stop it.  Brake fluid level is high enough.  I will bleed them tomorrow.  Any aftermarket recommendations to really make this this stop from the rear?
Looking forward to the responses.  Suspension is next!  I'm 6'6" and 300#.  Kind of a unique challenge - I know.  Been dealing with it all my life.
Just maintain the brake system and you will be fine
- fresh oem or organic pads
- clean the disc with cleaner
- tighten up the metal retainers to hold the pads really tight in the caliper
- put copper grease on the non-pad sides of the pads
- inspect the line for bulging, and replace with braided Galfer or Braking line if needed
Stock, usually the problem is way to much sensitivity.....
Thanks.
What do you think of "sintered" pads?  Seeing a lot of them offered but not any organics.
