2006 DR650 No electrical power.
My 2006 DR650 suddenly wouldn't start the other day. All was fine until I hit the starter switch and I heard a small "pop" from the right side of the bike and then all electrical power was gone. All fuses are fine, battery fully charged, all connections are tight. Could this be the starter relay causing this to happen? I hauled the bike home and electrical power had returned, when I tried to start it I heard the same "pop" and lost power all over again. I assume the ride home in the truck jiggled something back into place so the problem manifested itself all over again. Any ideas?
check to make sure your battery connections are tight at the battery, relay and frame. If those are good, and the problem still exists, try jumping the starter at the relay by connecting the cables from the battery, and the one to the starter. If the starter works, then replace the relay
