1982 KX125 jetting
Hey guys, I have a 1982 KX125 and need a needle jet for it. The jet is # 5E31 and obsolete.
Wondering if someone knows what other needle I could use in its place.
Thanks!
Is that the stock needle and you are replacing it for some reason or are you changing the needle to make the engine run better ?
Yep that is the stock needle which I broke :(
Now I need to replace it with something close. I've found a 5E13 but unsure of the difference or how it will affect the performance
In some cases u can go up in years on your bike and order stuff for it ,like here's a example I have a 1986 kx500 getting parts is not easy so I use 1988 kx 500 cause some of that will work
