Balancer shaft needle bearing
Does anyone have a good idea on how to possibly remove the balancer shaft needle bearing in the left case half without damaging the bearing? I have a blind bearing puller kit, but I see no way to remove the bearing without completely destroying the cage. Is it even possible to pull this bearing without damaging it?
Thanks for any and all help.
Edited by motoXfmX27
Why are you removing it? I would never reuse a bearing that has been pressed/pulled out.
