Odd question about 01 drz250 swing arm
I am trying to adapt the swing arm to use on a dr350. It looks doable but the shock linkage sits back just a tad on the drz250 arm and it looks like my dr350 linkage might hit the inside of the hole the shock rides down in. Question is do you think the bar that the shock linkage tube is on is solid? How could one tell? It all looks cast. If it is then I could grind the clearance I need. Otherwise I guess I could make new linkage arms with a slight bend. Would rather use my grinder.
