kdx rear fender
Does anyone know what year motocross rear fender will fit or be close to fitting on a 1990 kdx200? I just bought a CA street legalized kdx200. It is currently plated but no lights. I looked at the D/S kits and think a motocross rear fender would look much nicer with the aftermarket taillight. Thanks. P.S. Anyone have a service manual upload?IMG_2198_zps065ce326.jpg As you can see the PO bolted the across where the rear light used to be.
maires is the only one that makes a bolt on mx rear fender for the kdx200/220.
KX500 rear fender is a bolt on. 88-04. 88-89 KX125 and 250 shares the same fender.
KX500 isn't a MX style rear fender really. The KX125 or KX250 MX fender can be made to fit with some modding,
http://www.kdxrider.net/forums/viewtopic.php?f=77&t=14303
http://www.kdxrider.net/forums/viewtopic.php?f=77&t=12890&p=121747
here is a tutorial putting a KX250 fender on a KX500. Same process as the KX200
https://drive.google.com/folderview?id=0B_WoeuIlDLfTenFQSFlHa1lRazg&usp=sharing
Well since the KX500 is/was a MX bike Id say its a MX fender. That was how they looked back then. The 88-89 125 and 250 shared the same plastics as the 500. 89-94 KDx200s shared the same side panels as the before mentioned bikes and had similar body lines to the KX. You can mod a later year KX fender to fit but none seem to match the lines quite right in my opinion.
