Kdx 200 gas mixture and oil?
I am purchasing a 2001 KDX200 this weekend and I wanted to get everyone's input on what 2 stroke oil brand does everyone use and also what kind of transmission oil I should put in it also. For example the brand and kind. I want to find out what is gonna run best In the kdx200. Thanks!
gold spectrem 2st oil mix 1 bottle to 5gals of gas, belray gear saver oil for the tranny poar the hole bottle into the tranns, been useing this since 1984 have had know problems,
As a rule of thumb I NEVER use the " 1 bottle per 5 gallons" theory. You could read it incorrectly with BAD results. I stick with a ratio rite cup and measure accordingly. Always mix your own fuel, 32-40:1 with any of todays full synthetic oils is plenty safe.
Edited by ickfinger
1 bottle of gold spectrem oil is 40;1 mixed with 5gal
Edited by 1274
No its not. Golden SPECTRO comes in a 12oz bottle unless things have changed recently.  Do the math. Correctly.
Edited by YHGEORGE
Hence the reason for the ratio rite cup, takes away any guesswork or stupidity on my behalf. Sometimes I might need fuel out on the trail and If I've mixed it all using the cup, I can grab some from any buddy I'm with. I hate doing math and second guessing myself.
I use a 16 ounce bottle of full synthetic Redline and mix it with 4 gallons. That gives me perfect 32:1.
Edited by CR125-TAHOE
Then what do you do when your fuel can is half full and you want to head out for a weekend ride and have that 5 gallon can full?
Buy more oil.They usually have a sight window and its not that hard to do it with that. However, I do have a Ratio-Rite.
Edited by kdxphonedude
Then your'e still estimating. Ill stick to my cup only. I had a KTM in the early 90's, 40:1 it would foul a plug if left to idle too long, 32:1 would be fine all day. Edited by ickfinger
In that case i would use this measuring sringe that i have. But pretty much everytime i get gas i just put four gallons in my 5 gallon tank and use this meathod.
