Sorting out an EG 295
So I put my bike back together 2 years ago with an EG 295 kit, Mid-Top Race gas, heat cycled it a couple times, ran it around the yard for 5 minutes.  It was clearly way off on its state of tune, but I didn't have time to mess with it.  Now 2 years later, and 3k miles away from where I started it, I am finally ready to get this thing ready to ride.  I maybe started it 4-5 times in the last two years to load it in the back of the truck a few times to transport it, It always started second kick.
Heres what the jets were then.
Pilot - 50
Needle - 2nd clip
Main - 178
Power Jet - 50
It ran great as a 250 like this in the northeast at 1k feet, but fell out quickly when I was close to full throttle when it was put back together
So here is where I am now:
I cleaned the carb, tossed a few new parts at the carb, set the float level and slapped it back together with some fresh C12 mixed 32:1 with Klotz R50. So-Cal at sea level
Jets -
Pilot - 42
Needle - 2nd clip
Main - 172
Power Jet - 50
I checked timing, and it was at .012 btdc which is I believe around 1.5 degrees advanced, so I set it back to .007 btdc.
ran it and set the air screw. I started with a 45, but ended up with a 42 to get the fastest idle at 1.5 turns out.
I then ran it up and down the parking lot a few times, and it definitely doesn't completely fall off like it did before the carb clean and rejet.
I found an old compression tester kicking around and tried my hand with that, and got a reading of 195psi. I'm not sure if this means a lot with an old beater of a compression tester...
I am pretty new to the jetting game, so here is a pic of the plug, I ran this plug for 20 minutes or so around a parking lot, mostly mid throttle with a couple quick twists to full.
Any suggestions? is the plug helpful here? its not quite what I expected to see. Or do I just keep messing with it, needle first then main and see how good I can get it with some plug chops? whats with the little bit of white left on the porcelain?
Pipe is a Noleen, Silencer is a Pro Circuit 304
Thanks in advance!
Edited by CodyJ
I have no specific advice for your 295, but I have found that paying attention to how the bike runs and how hot it gets to be more useful than looking at the plug. I want the plug to be NOT white, and then I tinker until I get little or no spooge, good throttle response at different openings, no weird noises, and a cool running engine/pipe. Kind of hard to describe a cool pipe--it's obviously too hot to put your hand on, but it's not even close to 4 stroke hot.
Thanks, I figured I would just keep tinkering with it until I got it right, I don't think I've ever seen that 1/4 moon shape white mark on the porcelain of a plug before, so I'm curious what that means if anything?  Any idea what pipe surface temperatures I should be looking for?  I promise to post some really cool thermal images of it the next time I get a chance to mess with it.
and one more pic for good measure, because nobody likes a thread without pics.
I have seen plugs like that, mostly with the white part facing the intake.
Visually mark the plug on the insulator and twist it in until it is tight, I bet the lighter end is facing the intake
I am sure a quick call to Millenium Tech could get you a ballpark jet size for your setup: 1-630-825-5645
Thanks, Ill give them a call.  And I'll check the orientation of the plug later tonight.
and to keep the pics coming.....
Well, their website says you will probably have to lean the jetting a bit, and the guy I spoke to on the phone told me he had to go up two sizes on the main, and left everything else the same.  I guess I'll just have to spend some quality time with it.
+1 for that.  Totally agree.
Not only could I not be bothered checking the plug I think the tune by feel method is better anyway. Ultimately if you're not happy with it, then you feel it.
CodyJ,
The main tricks are:
1. to begin to learn what jetting circuits control which throttle opening amount, and where you are in the throttle range.
2. To be able to feel and hear a rich versus lean condition.
3. To feel if a problem is under how much load, or constant throttle, and how much overlap there is between the different fuel circuits.
It's not simple, but you get a feel for it.
Some guides say start with the pilot, or the main or whatever. I usually start fixing what feels worst. If I'm not sure what feels worst then I fix the main jet size because testing with wide open and some load is so easy to tune and improve. Then I keep refining.
On the PWK38 on the YZ250, in my personal experience only, these circuits do this:
- air screw: Tunes the pilot, but seems to have most effect at lower RPMs.
- pilot jet: idle to about 1/4 throttle. Up to 1/2 throttle is impacted by the pilot size if quickly opening.
- slide #: About 1/8th throttle when held quite steady. Too rich and there is a burble here.
- needle clip pos and needle shape/taper: 1/4 to 3/4 throttle.
- main jet: 1/2 to wide open.
In my own YZ295, at sea level, in moderate temps and humidity with 40:1 premix, Fatty pipe, stock silencer, 1.65mm squish, 240 psi comp, stock PV spring, and Aus 98 fuel, my motor runs brilliantly with:
pilot=45.  Any richer and it has spooge and fussy idling. Any leaner and I get hesitation.
screw=1.5 tuned a little for the day.
slide=#8   to remove the rich 1/8th burble when rolling open or cruising on flat ground. So much better!
needle=W on clip 3. Which is richer than the stock clip 2 pos, but it gives me more responsive broader roll-on torque, and compliments the leaner slide.
main=172.  Which I know is just a tiny bit rich for hotter days, but generally nice. A 175 wont rev out, and makes way less power.
My combustion chamber is usually a clean golden brown colour. Motor runs freakishly cool, at least compared to my 4 stroke. Torque and sound is awesome.
Edited by numroe
My 295 runs pretty well with stocker jetting.
Gorr says lean it but i dont find that to be the case with mine with a pipe n silencer in so cal.
Im not very heavy on the pipe but when i am, it cleans up nicely.
Plug readings arent a good way to jet.
You may be dealing with the C12 factor. Ive had more than one bike be difficult to tune with C12. Runs rich. Ive tuned a bike with VP110 to perfection and when the owner switched to C12 it was unrideable.
Your plug looks rich. But the ideal way to plug chop is to warm the bike up on a old plug. Install brand new plug and run full throttle for 1/4 mile.
Then pull the plug and inspect. I would lower the main one size at a time and do a plug chop after each.
