Anybody install a Yoshimura brake celvis ?
I just install a zeta brake clevis, it should be the same unbolt it off yr lever then using 2 10mm spanners one onto the piston end to hold in place the just unwind anti clockwise your standard clevis, hope it helps
when putting the new clevis on do you screw on a tiny nut under the clevis?
I'm pretty sure the little 10mm nut sits on top of the clevis, and and you back it off the top of the stock clevis, you can stick a screwdriver to hold the stock lever in place.
