carby help
Drz 400 e 2005 model
Hi I had pulled off my carby today to clean it out because of fuel dryed out in the bowl
I had put it all back together and now im having the symptoms of popping at high rpm like not enough fuel
Is this because my pilot air screw adjustment or somthing else
Because I could not remember how meny turns out it was
I did 1 3/4 turns out
Popping as in back firing or loss of power ? That would be your main jet if its over half throttle, put a fresh plug in it, double check the main jet, and air jets and try again.
Go out half a turn on the air mixture, fresh spark plug and main jet, it could aslo be an ignition problem but check those first to save yourself time
