DR350 shuts off when trying to shift
Ok i am sure this has been talked about before but everytime i try to shift the engine shuts off? I have already unhooked and wired the kickstand killswitch up. Thanks for any replys!
You mean when you try to go from nuetral to 1st? Or when you are moving and shift to a higher gear? And does it shit off before or after you let the clutch out?
So your bike idles fine and just cuts out when you shift down into first?? And before you let out the clutch? So you can sit on the bike, with it running, in neutral, and it's seems fine. Then u pull the clutch and click down and it cuts out?
Don't let Monday ruin your Sunday!
Yes that is exactly what is happening.
Try giving it throttle when shifting into first. If that works, then raise your idle. If you have the 350s, i k ow that some of them came with a kick stand switch that would kill the bike if you put it in gear with the stand down. That switch could be defective? This is a tough one
i have the switch disconnected and wired together so i am thinking the clutch just my not be disengaging?
