Best 2 stroke engine oil?
I have a 1991 kx500 what is the best engine oil I should use ? I normally mix the gas with Yamalube 2R is this the same oil u can put in the bottom end?
If I understand you correctly, then NO!  you mix your gas with 2 stroke oil, which is completely different than the gear oil your bottom end needs for bearing protection.  whatever you use, it should be a motorcycle oil for wet clutches or it might cause your clutch to slip
In my 2-stroke Suzuki RM250, I always use Lucas 10w40 semi-synthetic motorcycle. Mostly because it's so easy to find, no matter where I'm riding, I can grab a quart from O'Reilly Auto Parts.  It does say it's made for wet clutches on the bottle.  It's definitely not the best oil, but I like it. I have always heard bel-ray gear saver is good stuff.  it sure is expensive.  Some guys use ATF because it makes the clutch feel different & it's really cheap so you can change it a lot without breaking the bank, but I'd be worried that doesn't provide enough protection for my crank bearings on a long trail ride or hard ride on a track...  My buddy runs Royal Purple gear lube in his CR250, & while it probably provides great protection for the crank, it probably slips slightly more with the clutch than a "wet clutch" designed oil would...he still beats me through the trails tho!
Edited by chevyrulz
Yamalube 2R is great oil for the top end. As for the bottom end I would stop by Wal Mart or your local auto parts store and pick up a gallon of Shell Rotella T in the white bottle. It's cheap and does the job!
I have used Golden Spectro semi syn. In tranny. 80 wt. Also their 2 stroke oil mixed at 50:1
Cr500. Desert racing. My engine's have lasted seemingly forever. Yamalube burns dirty and leaves deposits. Spectro doesn't.
  • Like 2
Anyone who thinks that ATF doesn't supply enough lubrication for their bottom ends should go have a look at the odometers on their automatic equipped cars, and trucks. There's bearings, and clutches in them.
The oil you run in your tranny has nothing whatsoever to do with lubricating the crank bearings.
