Ice Cube jugs
Has anyone used the Ice Cube jugs. And if you have are they any good.
I use trays. Works better.
Yes. One cube or two lol
you talking about the square jugs with center cap?
Ice Cube are racing heads made by Max RPM.  I've no opinion on them.  Had friends that ran them on quads back in the day.  I'm not the one to ask though.
Edited by Slackkinhard
Or these?
They can be fun, when cold as ice cubes!
Edited by ridngslikecrack
I had one and it was very well built but it used an o-ring head gasket from a YZ.  The gasket would blow out every five months and fill up my crank cases with rad fluid.  I had to lap the head and cylinder every time I took it apart because the metal to metal contact caused it to distort. If I remember right the cylinder used a hard plated liner that for me maintained really good compression much longer than any OEM cylinder.  That was back in '06 so hopefully they fixed the gasket problem.
Edited by Float
