Kx500 jetting problems?
I just bought a 94 Kx 500 it has just had the top end done and replated and is bored to a 510 and has an fmf full exhaust and I am having trouble getting it to run correctly. It's got a keihin 39mm pwk carb with a 180 main and a 58 pilot. The needle clip is in the #2 position. It runs really well until it begins to get into the power band, then it breaks up and feels as if it is leaning out. The jetting seems a little rich to be leaning out and I'm all out of ideas. I have tried the air screw from just 1 turn all the way to 5 turns out without any noticeable difference. I'm 200 ft above sea level. I run a 32:1 castor 927 premix in 50/50 pump gas/race gas. Any help getting this beast running correctly would be much appreciated. Thank you.
I am happy to report that I solved the problem with y'all's help. Before I did an engine leak down test I decided to move the needle clip down to the middle and eventually down to the very bottom slot. Every clip position change duplicated the results I had before when I had the needle in the #2 slot except worse in every way. The farther I went down the needle the worse it got. It bogged earlier and more often, had excessive smoke out of the tailpipe, etc. This obviously tells me I have been running way to rich and that I need to lean out on the jetting. Thanks for the help!
