gas tank 2014
i checked out the part numbers and its the same at rockymountainmcatv but there are some gastanks with several mounting holes for radiator shrouds
so does a 2009 kx450 gastank fit a 2014 kx450???
Absolutely not, the frame was narrowed and the shrouds are different and when you look up the part numbers on rocky you're only getting half of it.
Fuel tank complete 2009- #51001-0031
Fuel tank complete 2012-2014- #51001-0412
Plus the tanks are different sizes. 09 holds 1.8 gallon and 14 holds 1.6 I think it is. The 11's tank is a different number from the 09 and 12-14. So to answer your question, 2012-2014 are the same.
Edited by duhameister
