DRC 602 flasher stopped working after one week. HELP
I noticed today that my front right DRC 602 flasher stopped working (only installed for one week).  The rear right and both the front and back left work fine.  I tried swapping back to the stock relay and still nothing.. Check the wiring and all the connections seem good.  Am I missing anything else or is it possible the bulb just burned out?  I did buy one of those cheap relays off ebay to get the flashers to blink at a normal rate and it works fine.. Not sure if this had anything to do with the problem thought.. Is it possible to just replace the bulb at say a auto shop? or does the whole unit need to be replaced.  Any tips would appreciated..
