Throttle/carb issues
Have you taken off the cover(throttle grip)  from the carb? check if cable is stuck or the if pulley isnt coming back when you twist it. Cable must be torn or pulley spring, or pulley itself
The problem is most likely either cable routing, cable needing lubed, dirty throttle tube, throttle tube contacting the bar end if you have barkbusters installed, or the inside cable is frayed. It only takes minimal fraying of the cable to make it hang up.
Take the cable off the bike and the check its free movement in and out by hand. That also lets you check other components of the system individually.
