Sisneros single pull throttle cable replacement?
I picked up a single pull a couple years ago when someone was still in business. I understand the cable was a custom fabrication, does anyone make a replacement or is there a work around? Thanks in advance. S.
You can remove the ends from the old cable and re drill and re-solder them on a new cable, I've done this before there are videos on the net if you search. Just need the correct flux and solder
I know "someone" still has the cables but that's a risky way to go.....
Getting custom cables made isn't that hard, and you'd actually get your parts on time. You can send motion pro your old cable and they will make one to match it.
  • Like 2
I
I did this and they did an awesome job, their cables are way better than OEM. They were super nice on the phone.
  • Like 2
