Speedo reads 299 when stationary?
My speedo started reading 299kmh when turned on. Im confused as to what is causing it. Id appreciate any ideas you may have..
The pre 08 450X AUS speedo's were made by Acewell, These were known to stuff up also, 08 onwards they fitted a different speedo that works off the rear wheel & they were not much better, I removed my stock speedo & sender setup somewhere around 500-600 K's I think basically to fit a speedo setup with the temp readout, They were working fine when I removed them
I still have them if you are interested?
The other option is to fit a Trailtech Vapor speedo If you can do some basic mechanical work & you know how to use a multimeter?
I just happened to bump the instal thread up too>
http://www.thumpertalk.com/topic/634283-how-to-install-a-trail-tech-vapor/
