DRZ400E Conversion To SM Lighting issue
So i have recently got my hands on an already converted E to SM DRZ however, the headlight and tail light will not come on upon starting the ignition or turning the bike on yet the brake light still works? i've checked the bulb in the headlight to outline whether it was that or not but unfortunately the bulb was not the issue. i'm hoping its something quick and simple to fix and not something im going to have to take the entire bike apart to get to the loom for. any suggestions on where to start before i start blasting the bike apart to look at the entire loom?
Any suggestions are appreciated :)
P.S its an 05 Drz400E with 9k on the Clock
-Check the fuses under the left (opposite of the exhaust) cover. (they are just above the battery)
-Get a multimeter and check for voltage at the light with the ignition on.
if both of those are good then check the wiring, there will be a broken wire somewhere.
Thanks Phanton, ill have to try that tomorrow, its got abit late atm and bit too dark for me to be messing about with nuts and bolts, but ill inform you on progress tomorrow :)
