2009 kx250f clutch problem
My 2009 kx250f clutch will not disengage. We have split my cases twice, just to make sure, but we still run into the same problem. Not sure if its my transmission, actual clutch, push rod. Any help will be greatly appreciated!!!
Keep it simple and readjust the clutch cable. I had the same problem after rebuilding my engine and i felt like crying.  There should be about 1/4 inch of play on your clutch lever.  Try that.
has your basket and inner hub been changed?
Did you put the ball bearing back thats at the end of the push rod ?
