Shimming valves on 2009 kx450f- tips?
About to check and probably shim the valves for the first time on this bike. I don't have a manual and used search for common thread style directions but didn't have much luck.
I'm familiar with yamaha, I'm assuming it's the same concept. Lobes out, sprocket marking out and level with top of head, is there only one marking on the flywheel to help find tdc on crank?
Torque for cam cap 7 ft lbs?
Tightening pattern?
Clearance specs for intake and exhaust?
