how do i lower my 1992 honda xr250l ? is there a link made for it ?
the bike I thought would be nice and friendly for her is about 3 inches high please help
Shock can likely be shortened internally even if it is not a rebuildable shock.
The forks can be shortened internally as well.
Cost if the shock is non rebuildable type about $175 range and similar for the forks.
You also can trim the seat down. May affect comfort but does lower the bike.
Supermoto wheels.
THERE IS A NOTCHED RING AT THE TOP OF THE SUSPENSION SPRING. YOU CAN TURN IT AND COMPRESS THE SPRING AND LOWER SEAT HEIGHT. THERE IS PROBABLY A TOOL FOR THIS BUT I TURNED THE SPRING USING A SCREWDRIVER AND TAPPING WITH A HAMMER. YOU WILL HAVE TO TURN IT SEVERAL TIMES BECAUSE THE RING IS FINELY THREADED.  IT IS A LITTLE TIME CONSUMING BUT WORKS. I EVENTUALLY RETURNED MINE TO STOCK HEIGHT BECAUSE OF RIDE QUALITY. GOOD LUCK!
