Moose top end gasket question
I have a Moose top end gasket set part # 0934-0071; why is the head gasket two separate pieces with two rivets holding them together?
That's how a head gasket is supposed to look on this bike. Just run it.
Not what I asked; I asked "why" is it like this, not what its supposed to look like. I'll email the manufacturer and post their response here if I receive one in case someone else wants to know.
It's riveted so the 2 pieces don't separate. Run it.
it should be 3 parts the outer are spring steel with raised sections to seal the inner section controls thickness becarfull the moose gaskets are thiker and you will end up loosing compression ratio .
