leaking cam chain tensioner
 Thanks for your help. I just had my valves adjusted and a good amount of oil is leaking from the cam chain tensioner. I don't have any experience with this. Can I just pull it out and replace the copper gasket?. I checked to make sure its tight.
Hey Jerry, did you check the parts schematic to see if it's a crush washer or an O ring? Should be an easy fix, who did the valves for you, what year are you working on?
George did em for me. I think I just have to remove it,heat up.the washer and reinstall. If not ill replace it.
Its an. 11 like yours
