Pistons: single vs normal?
Im doing a rebuild of a honda cr250 2000 and looking for piston and cobrod kit when i saw a single piston? Its shorter with 3 rings... will you need a longer conrod when using single? And whats the ups and downs com paired to a bormal one?/? Still deciding between ProX ans wisecon piston and conrod...
I think your confusing a crf 250 piston with a cr 250 piston.
  • Like 3
A 2000 model Cr 250 has a double ring anyways , One reason i like my 01' better than the 05 i had , i just believe it's a better design and that extra ring isn't going to save that much weight .  :lol:
I run a single-ring Wiseco Racer's Choice in my KX250. I also pay the extra few dollars for the TiN-coated ring, so the ring actually outlasts the piston. The reduced drag makes the engine noticeably snappier.
OEM pistons for 250 two-strokes are two-rings.
If you're looking at a piston with three rings, it's for a four-stroke.
A single-ring piston isn't about weight savings, it's about reducing friction and drag. But it is lighter as well, because you are also losing one of the ring lands in the piston.
You can actually run just a single ring on your two-ring piston and achieve much the same effect, although the extra ring land will make the piston still weigh more than a true single-ring piston.
Edited by Chokey
I read somewhere the 2 ring design will steady the piston better and reduce piston slap after the cylinder has some wear ? Idk I get the friction thing and again don't see a problem , with proper jetting , good oil being used and good coolant .
Probably heard from the same dummy who said namura pistons were ok
I happen to like namura pistons  :p when i replace them or do my top end service they usually still have the moly coating on the shirts with 40-50 hours on them. I will NOT run a dirty air filter or an egg shaped cylinder though , or maybe i just get all the good ones and everyone else gets the bad ones  :thumbsup:
  • Like 2
The piston is still the same length, so stability wouldn't change.
There is less metal in the crown though (only one ring land to reinforce) and less drag than two rings.
Coming from the dummy that thinks there's something wrong with Namura pistons.
Edited by Chokey
  • Like 4
Well yeah, it's the piston manufacturer's fault, not the guy that ran the bike with an airfilter that had a hole in it.
Edited by MaybeMe
  • Like 4
Or never gapped the rings in a cylinder with 500 hrs. on it
