Cr 500 decompression valve
Who can put a decompression valve on my 86 cr500?? Im in Australia.
If noone answers you, you can head over to bannedcr500riders.com or the regular one. They're entire forums dedicated to them, and I'm sure someone there will know.
You probably can, with a little help from some friends. I use a decomp unit from a small 2 stroke, chainsaw, disc cutter type thing. They are normally an m10x1 thread. I had a local machine shop make a sleeve, with an m10x1 female thread in it. I used a 2.5mm drill bit, and drilled horizontally between the water jacket and a stud hole into the combustion chamber. I had the sleeve welded to the head, screwed the decomp unit in, bolted it in to the bike, and fired the sucker up. Cost me about £20.
