xr 100
My daughter dumped her xr 100 in a ditch full of water and it hasn't started since. Cleaned the carb, put in a fresh air filter, and plus still has spark. Changed oil too any suggestions?
Does it run with ether (starting fluid)? If so, you've got a carb problem still. If it doesn't run with ether, you could have damaged the valves causing low compression, a host of potential problem if it won't run with ether. But try starting fluid and see if it runs.
