2012 yz 250f jetting problem/bog
Just bought a 2012 yz 250f with hot cams, high comp piston and full dr d exhaust. Ran good then I put a jd racing igniton, black ops moto coil and r&d power bowl on it and now it seems no matter what I do it bogs on quick throttle on and off the stand, not sure what else to try or do, any suggestions on what it could be ?
Did you install the R&D linkage spring upgrade that came with the bowl?
If so, you probably did not hook the spring on the linkage correctly, and now you have a non-working accelerator pump
It's easiest to do with a dental pick after it's installed
Edited by TheKoolAidMadeMeSick
