Will 2014 yz250 wheels fit a 2006 yz250?
Like the title says I'm looking at some yz wheels off of a 2014 for my 06 I thought the axles where different size for some reason. Any help is appreciated
Bolts right up. Same axle part number, just for the record.
If youre familiar with motosport or rockymountainatvmc, they have easily searchable fiche for such ventures.
Uh no, axel size on the rear was changed to 25mm (in 2009) vs the YZs 22mm and the front axel went from 20mm to 22mm in 2014....
Edited by Monk
Same axle part number. 2 in stock. Im usin a pre 2006 wheel on my 2013.
13 had a 20mm front axel, 2014 went to a 22mm front axel
In 2009, they went from a 22mm rear axel to a 25mm rear axel
http://www.dirtrider.com/features/first-look-all-new-2014-yamaha-yz250f-and-yz450f/
"The 250F’s fork and rear shock have new spring specs to compliment the all-new frame and the shock’s reservoir went from horizontal to the more-common vertical arrangement. Up front, a larger 22mm front axle with a new top triple clamp increases rigidity while rubber mounted bars keep things from getting too stiff. Last of the major changes, the air filter finds a new home in front of the gas tank just like the 450F’s"
Edited by Monk
Thats for a 250F.....im assuming hes talkin about a 250 2t in the smoker forum. Or im lost in thumpertalk. Lol
I think I'm lost! I swear it said 250f in the title but I guess not.....
But in that case, yes, 2014 YZ 250 wheels will fit a 2006 YZ 250
Sorry for the confusion OP.....
:facepalm:  :facepalm:  :bonk:  :bonk:
Assuming both two strokes, there the same. Just make sure to use the 06 front wheel spacers and not the 14 ones if you end up with them.
Yes both 2 strokes thanks a lot guys appreciate all the info on this page.
