Need Help With CRF70 Engine Stall
My CRF70 will crank and run fine for about 10 minutes then quit. It has to cool down before restarting. I'm thinking it's an ignition issue but not sure which ignition parts to change. Should I start with the coil, CDI, or would it be the stator?
carb clean, replace air filter, replace plug, check valve lash, clean out exhaust plug screen, and use fresh gas.  then try it and tell us.
