Shock clevis material ?
Is h15 alloy a suitable material for a shock clevis ? It's a copy of a linkage wp shock clevis so it's really beefy not like a ohlins that's almost tiny in comparison
Hey Mog, is this a project still going did you do something with it?
Would be interestiing to know
Was working on it 5 minutes ago , got a clevis made in 6081 t6 I think , it's been a nightmare or a project , might ride it tomorrow will let you know the results
Are you making your own shock then? :) that could be fun
It's a kyb shock body from a yzf 250 2009 , the shock has the big reservoir , then the shaft is from a 2006 kx125 so it's 16 mm and a hand made milled clevis , skf seal head and a ti 4.9 spring from a 2006 , the assembly is 0.6 km lighter than a the wp original which is a nice weight saving , but it's been a horrible project !!!!
  • Like 2
It's going into my sxf 250
Finally made some progress , it's all fitted and working , it does have a different feel to a Wp and much more like a wp trax , it was a super bumpy hard pack track with tons of acceleration chop and breaking humps , it swallows them unlike the Std one even when revalved , it doesn't transmit the track to the rider like a wp does , it still coped with hard landings well and didn't bottom harshly , over all really pleased and after 5 20 minute sessions I feel fine , im 42 now with a shoulder injury so that's often not the case after a good amount of riding
Edited by mog
It displaces more fluid through the adjuster and can cause a spike in the hs , the later kyb went back to 16 mm shaft as did the factory bikes
it feels as good as the traxx shock?
It's simular in feel but I'm not saying it's the same or as good or better or worse , it's just one track and I'm going against memory , what I want to do is get Karl ace with me at a track and test this shock (once stiffened a bit ) against the best wp revalved shock and also one I have(wp) with a smaller port piston and see which one feels the best
Which piston did you use for smaller port if i may ask mog?
Did you try GV?
It's a vrs piston came in a shock from eBay
how about the rebound needle adjuster did you make your own or used the KYB ones?
I used one from the yzf shock , I was not sure it would work with the 16mm rod but it does
