Pulling to the right under braking
I bought myself an old rat XT350 with the intension of restoring it.
Any way, after 4 months of hard graft it's finally finished.
What I have found out it pulls alarmingly to the right under braking !!!  :jawdrop:
The front forks were stripped and also new headstock bearings were fitted.
Could it be the fork yokes aren't true or maybe something else.
Thanks folks.
Maybe you are flexing your right arm when applying the front brake?
The placement of the rotor won't have any effect on the bike pulling one way or the other.  You only have one front tire, it should track straight when applying brakes.  The only thing I can imagine causing it to pull to one side or the other is operator input.
