Wr450 bark busters
I just got some moose bark busters for my 2008 wr450 which still has the factory pro taper yz high bars. They fit like crap! According to the customer reviews on dennis kirk these were supposed to be a good fit for tapered bars.
I know a lot of people say that any kind of busters you get you have to bend to fit but what does that really mean, because these arent even close...
What does everyone else run on this bike for bark busters? Thanks.
I can't ever remember installing a pair that didn't require a bigger hammer.
They all require some level of massaging, or some level  of more expensive hardware to make them fit.
What your picture shows is absolutely typical of 'generic' mounts; they will work fine however.
Cycra probend with CRM mounts are my favorite.
Barkbuster bark busters on my Protapers (Windham), they fit well 'cos an Aussie bloke made them in his shed   :thumbsup:,didn't have to bend anything. Had a set on my dr too, no fitment problems (TAG tapered bars), and another on my TDM900 (7/8 Renthals), also good.
Did you bolt it all up loose, get everything lined up, then tighten the bolts?
Are you sure the clamps are for tapered bars not 7/8 bars (could have been a stuff up when they were packed up and sent)?
Use Zeta ones on mine
They have a pivot point in the middle of the clamp/leg, which yours do not appear to have
As they clamp on the tapering portion of the bars, you have to get them in the right position so the diameters match and so you get full contact between clamp and handle bar
As the OP has his, hey will move the first time he hits the deck resulting in possible broken levers
Best fitment method is to find the optimum place for the clamp, and then make the rest of it fit to it, rather than allowing the clamp to go where the re-enforcing bar wants it to go
I have a set of AUSTRALIAN made "BARK BUSTERS" fitted to PRO TAPER 7/8 PASTRANA/FMX BEND. No problem at all fitting them.
We manufacture a comprehensive range of mounting kits to fit most brands of handlebars.
The large variety of tapered handlebars on the market have many different degrees of taper and thickness. To mount a handguard securely it is important to match the clamp kit to the handlebar correctly.
The legendary EGO handguard has proven itself as the toughest and most durable handguard on the market.
Super strong aluminium backbone is integrated into the replaceable plastic guard to create a strong functional handguard.
The EGO’s compact design is ideal for Trail and Enduro riders who like tight single line bush riding.
ImageUploadedByThumper Talk1400968534.425445.jpgImageUploadedByThumper Talk1400968550.579178.jpgImageUploadedByThumper Talk1400968559.276312.jpg
attachicon.gifImageUploadedByThumper Talk1400968534.425445.jpgattachicon.gifImageUploadedByThumper Talk1400968550.579178.jpgattachicon.gifImageUploadedByThumper Talk1400968559.276312.jpg
http://www.barkbusters.net/
I have used the old original design VPS Barkbusters on my last three bikes, they give a little more room for the levers, and allow for fitting the larger Storm plastics in winter. But I'm in the desert, not a lot of real tight woods riding here...
They also have a lighter duty type without the strength of the aluminium bar. If ya ride desert you shouldn't need bark busters? Nothing to run into ie: trees etc...
If there was only one tree in the paddock I'd manage to break a lever on it.....
Mallee desert, lots of trees, just spread apart.  Plenty of random rocks to drop the bike onto as well.  Gum trees along the river are a few feet across, don't move much when you hit them, but they're not close together like pine forest etc so not too hard to avoid.  Mostly.
One track I was riding yesterday had a shrubbery along both sides, bars were constantly hitting the hopbush.  Barkbusters stop the front brake getting pulled on.  The lighter ones might save a few grams, but I'm happy with the ones I've got and maximum protection. Yesterdays ride was 330km, remote area, alone. I carry spare levers but I'd rather not break them in the first place.  Or my fingers.
:lol:  :lol:  :lol:
Um, ok, so we don't have any trees...
http://youtu.be/d2InmGEbWvg
I run "big ass rock busters" for the CA desert :smirk:
Edited by KennyMc
Fair enough KennyMc point proven lol. Eric's loop out was crazy man, so lucky he didn't get caught underneath it.
