12 KX450 Springs - 245lb rider
Anyone got any real world experience with spring rates on a 12 KX450?
Being a novice 245lb rider (without gear), I seem to get the following range depending on who I talk too.
The spring rates range I have so far:
Front forks :  stock springs through to 0.52
Rear shock: 5.8 - 6.2
I'm not a huge jumper, so don't need super heavy spring to take heavy landings, so I guess that could explain the range of 'generic' rates offered by various people.
I think from memory the bike come stock with 0.48 front, and 5.5 rear.
From those numbers, quite a range to choose from, so a bit lost on what to go for.   Do I shoot for the middle, 0.50 and 6.0?
From riding so far, I actually don't mind the front forks, playing with the clickers I have them feeling quite good, although I'm sure they can get better (still not as nice as Yami SSS)
Shock spring I know I need to go heavier, currently have around 14mm free sag.
Any suggestion on what I should try?
Your standard fork spring should be a .52 kg and the rear shock should be a 6.3 kg for your ability and weight.
The rest is really based on where you ride and ability, but I would start there.
Edited by duhameister
I'm 246 and have gone with. .50 fork springs and 6.0 rear. Be careful with the spring calculators they seem to give incorrect values for heavier riders
