Brake problems
I have a drz sm. The front brake has no pressure. I rebuilt the master cylinder and still have no brakes. There is no loss of fluid. What am I missing?
Air in the line.
Sometimes you can crack open the upper line bolt and get it out that way.
Sometimes u can push the pads in and force fluid back up into the reservoir.
Mityvacs are $35 on ebay. I have one sitting on my front porch right meow.
Zip Ty the brake lever to the bars overnight, sometimes that works
My favorite way to bleed brakes (if there is a "favorite" way lol) is to use a vacuum pump at the bleeder to suck the fluid through the system. I rigged up a turkey Baster and some fuel line and it worked like a charm
The brake lever builds no pressure. I took the brake line off and pulled the brake lever. Nothing comes out. The rebuild kit didn't come with a new piston just rubber seals. Maybe I need a new master cylinder?
If you have trouble getting all the air out of the system try bleeding from the bottom. I use a big syringe i bought at a feed store with some tubing attached to it. Fill it with brake fluid and push the fluid into the bleeder bolt till it fills the master cylinder.
Try this.....Bleed it from the banjo bolt on the master cylinder.  Pump the lever a few times and hold it down while you crack the banjo bolt, snug the bolt up then release lever.  It should gradually build pressure.  Do this over & over & over, it takes a while and it's messy but it should work.  This procedure is called ' Bench Bleeding '.   :banghead:
Tried that still no pressure at all. Thinking the piston is toast. I might need a new master cylinder?
Expensive, but that would be my guess.  :angry:
