Clutch problems
Got a 2011 250xcf and can't ever start bike in gear with the clutch in or if I start the bike and don't let it warm up and shift it into gear (with the clutch in obviously) the bike will stall. If I don't let it warm up and I'm on the road where there is lots of traction I have to Rev it a bit and then shift it into hear so bike will not stall. Do not have the stalling problem when bike is warm. But I can never start the bike if it's in gear but clutch is held in. What's my problem?
But I can start bike if clutch is pulled in and in gear if the bike is still moving
Your clutch is not clearing (fully disengaging )
could be worn springs/plates/warped plates, clutch not bleed well, worn grooves in basket or hub, i would start by bleeding the clutch with fresh fluid and a inspect the plates/springs.
