Oil check bolt broken
So I was probably too tired while changing my oil tonight....But anyways went to screw the "oil check bolt" back in on the transmission side of the bike and broke the bolt off while doing it. What's my best option? Do I even need this bolt? Seems pointless.
Thanks for any help in advance!
i would pull the side cover off and use an easyout to remove the broken bolt. Then i would install a helicoil, since the threads are probably going to be screwed up.
