Dialing in the kx supermoto
Now that my kx is all ready to go, I need to dial in my jetting. So here's the deal. Bike doesn't like to cold start. Using the choke almost seems to make it worse. But it will start with the hot start pulled in after a few kicks, and I need to feather the throttle untill it's warm and it will idle fine. Starts up first kick every single time when hot when the hot start is pulled. When I'm holding steady throttle, the bike will basically sputter and kind of skip
Fuel/air screw 2 turns
175 main jet
42 pilot
Stock needle
Fmf powerbomb
Fmf ti powercore
Needle clip position, unknown
Elevation 1000 ft
This weekend I'm going to check my needle clip position, just looking for Input on what you guys think , too lean or rich?
The sputtering leads me to believe I'm running to lean since I installed the powerbomb, but the fact that I have to pull the hot start on a cold motor makes me think to rich, what do you guys think?
Edited by Bazuka Joe
Fmf calls for a
175 main
42 pilot
NCYS needle
Clip 4th position
2 1/2 turns fuel screw
At 1500 ft and 70F
