Shift shaft seal.
You'll need to drill holes in it and use a hook or some wire to pull it out. Good luck!
This.
A little wood screw works too. Thread in a little and give her a tug.
or use a pick that has a hooked end. Slid it in and behind the seal and just pull it out. I did mine the other day this way.
Ok cool, just replaced the shift stopper and swapped out the shaft on my 06 and the end if the shaft was bent! Had to cut it off with a dremel and then pull, very hard to get it threw, I also gummed up the seal and it's leaking a little.
Gonna order a new seal and swap it out!
Thanks all!
