prime oil pump help
put 1 qt oil in the valve inspection plug. put 1 qt oil in the frame tank. put several short bursts of compressed air in the frame tank. this will drive the oil into the pump on the pressure side intake. start the bike, loosen the head oil line slightly to see if oil comes out under pressure. thats it. if oil fails to come out under pressure, stop the engine, and repeat the compressed air and restart the bike.
